- Joined
- 8 May 2017
- Messages
- 10,669
- Reaction score
- 2,872
- Country
That makes sense, Thanks.
Can I save some of the system fluid by shutting the rads and just draining the pipework and leaving drain cock open as i repressure the ev?
Do EV's often lose pressure without actually failing?
Since you have been losing pressure ( water from prv ) and draining system several times , the amount of inhibitor left will be questionable. Drain as much as you like but buy a litre of inhibitor to put in once you have sorted your current problem out.
