Wc pan to soil stack connection
2 Feb 2012
Installing a new toilet that is about 2-3" forward of the one previously
My question is with regards to the waste connection.
There's is a small run to the soil stack which is the push fit type with ring seal in. Will this flexible connector fit...
http://www.mcalpineplumbing.com/4-110mm-plain-end-outlet-flexible-wc-connector-long-length.html
As the the end seems to be a pipe rather than all the others I have seen with fins.
Or, would it be better to add some kind of extension to the old soil pipe. It is joined by solvent so can I fit a straight section to the old pan connector to reach the spigot?
Can add photos if my post is too confusing
So just so I'm clear,
The finned type fit inside another standard soil pipe
And my linked one fits into my soil stack with o ring?
Probably use that then
Can a pan connector be increased in length or is it strictly just for going on the spigot of a wc pan ( can I put a straight extension in the old pan connector?
Cheers
Thanks,
Final question, are these flex connectors ok to use. I have heard they can block easily and as I'm boxing in the cistern and pipe it will be hard to access in the future
Cheers
A lot of plumbers dont like them, and I've know of one incident where the finned end (used to go into a floor connection on a ground floor WC), 'popped out' the floor when the drain blocked. The pan filled when flushed, the pressure displacing the connector, flooding the room.... :eek: (Replaced it with the 90deg rigid version, and refitted the pan after unblocking the drain, no further problems to my knowledge.)
Rigid connection may be better if possible, but in terms of sediment build up, McAlpine claim German tests prove the product fit for purpose.
