WC unit brackets for wall mounted toilets
31 Mar 2011
London
I've been looking to install a new WC into a bathroom that I am doing a complete makeover, and quite into the idea of having a wood-finish WC unit, with the cistern inside, and then having a wall mounted WC on it.
Its been hard to find a WC unit that has fixing brackets that come with it, but I settled on the Ideal Standard Slimline Concept WC unit:
http://www.qssupplies.co.uk/bathroom-furniture-shower-taps/9983.htm
It does have the option of Wall Hung WC bracket. However, I was wondering if the bracket is standardized, and will take any wall hung WCs? For example I'm looking at the Duravit Starck 3 Compact:
http://www.duravit.co.uk/products/s...compact--220209_toilets_93752_useo6q3rtg.html
I don't want to order both and then realise they're not compatible! Is the WC bracket compatible with most/any wall hung WCs?
I've looked at the technical drawings online and as far as I can tell the Duravit Starck 3 should fit the IS Slimline Concept bracket, the fixing centres, heights and pan connection height are all identical, so I'd say go for it
