I've installed a 1.5 bar pump under my hot water cylinder, the cold tank is above in the attic both connected with 22mm pipe reduced at the pump to 15mm inlets.
the shower is back to back with the airing cupboard, 2m max from pump to shower, each outlet (15mm) passes through a 90 degree elbow, the mixer valve, a 90 degree wall plate elbow, 90 degree outlet elbow and the handset.
the result is a shower comparable with the mains supplied electric shower in the main bathroom rather than being pinned to the floor in a torrent of hot water
is there a right angle too many or do i need a 2 or 3 bar pump?
Cheers
Cheers
