Weatherproof socket
20 Sep 2004
If using the correct spec cable to supply power to a garage from the house CU to a CU in the garage(not the Screwfix type) the cable which is in two sections because from the garage it runs under ground for ten feet then terminates two foot up the house wall, the cable from the house CU then meets up with the garage cable, Question, can a weatherproof outside socket be used to connect the two cables together,
if the outside socket has enough cable space and your cuircuit is breakerd at 32A i can't see why not
i don't generally reccomend putting sockets on cuircuits rated above that though
Need more info.
What cable are you using?
What is at the mains end of that cable?
How big is your cable?
How big is the protective device?
What is the loading on the cable?
in short, no, but i also agree with securespark, particularly loading on cable
If I don't use a weatherproof socket will a weatherproof connection box surffice to connect the two cables together, the reason i'm joining the cables is because I have recently moved house and the armour cable was already in place from the garage to the house the cable going under ground, cheers
