We have a small wooden window - very simple that opens outwards like a reverse cupboard sort of thing. There is no weather protection around the
window all around where it closes into the frame. What suggestions do you have for this.
There is not enough opening space on the hinge side to put cover strips or hinges that project the opening slightly to accomodate the window on the outside.
We could put cover strips on the inside that the window could close against. Someone suggested this rubber strip that you slot into a chased groove around all around the window frame and window. what is this called and where do you get it.
Any other suggestions?
