Mine doesn't, but I've got a client's whose does. Useless pointing as it turns out, NHBC are going to repoint the whole place. And that's the crux of the matter Guiseppe: a wall may not be suitably pointed, it may suffer from driving rain in an exposed position, in which case water can get through. A solid wall is twice the thickness - at least - of an outer leaf of a cavity, thus the chances of water running on the inside face are less, or did that simple fact of the difference in construction escape you? It happens on half brick walls on rear annexes of terraces - I've seen it and, as far I was aware, it was not due to some ongoing bout of "vicious fingering"...Does your garage leak when it rains
We lived in single leaf homes for millennia without water ingress into our homes.
Yes, Josephine. They are called caves. Although the single leaf construction is/was often much wider than those used in today's modern day construction they were/are susceptible to damp.
Yeh, ok Joe, the whole world is wrong and you're right, I made up those extracts from the NHBC Standards, yadayada...
I think that, if you enquire of the NHBC, you will be told that the Standards are not, as you state, the exclusive preserve of engineers, dumb or otherwise, but a conglomeration of information from other sources, including scientists, as well as guys on site. But that wouldn't suit your argument now, would it?NHBC standards are written by engineers - and we know how dumb they can be don't we?
By what tortuous route do the neuro networks in your brain connect? Do they connect at all? Do you actually have a brain?
You say that water doesn't run down the inside face of a cavity; I say it can. So do the NHBC, BRegs and any other authority building-related, as well as other posters in the forum. That is why the regs say weepholes and cavity trays are required in cavity work. You say that it doesn't happen in solid walls; I say it is less likely, given the relative thickness compared to a cavity outer leaf, but not impossible. You choose to ignore joints as a source of weakness in the wall structure as a whole; I point out that they can and often are. The only thing about which we seem to be in agreement is that they are not necessary in all the case that current regs insist we put them in.
If that's coming around to your way of thinking, then I'm obviously a banana.
Ooh, I missed this one. Yes, you're right, site guys are often a mine of information and I have no problem in asking their advice on occasions, not least as they are the ones who actually have to build what I design and detail.Thank you for your ungracious climb-down. Now let your ego drop. I've learned much from listening to the least educated brickies, plasterers etc. You can too.
