Weird leakage in the kitchen ???
16 Sep 2008
London
Hi all,
I have a leakage from a pipe which look like a nosal/nobe on car/bikes tyre which you press to release the air.
I dont know where the pipe is comming from as i can only see the little nobe/nosal which is poping out from a hole in the roof in the kitchen.
Any help or advice...please!
Many thanks in advance
T
It may be the air charge point for an expansion vessel which someone has fitted into your ceiling.
Before you touch it I suggest that you investigate from above to see what it may be. Take a photo and post it here and we can all guess at what it is!
Tony
Thanks Tony for your swift response.
I called in a plumber to look at it....he said he can't tell as their are tiles above the leakage area etc and he can't view the area properly he said that I shud ask a builder to break the tiles and than show it to a plumber etc.
I will have to arrange for a builder or perhpas show it to another plumber incase any alternative...
once again thanks for your help.
Cheers
T
If the tiles are on the floor above then its cheaper/easier to investigate through the ceiling.
Thats an easy DIY to make an access. I suggest about 300 mm away but in the same line as the joists then use a light and mirror to look at it or photo and post here for us!
Tony
Righ now Im at work...I will take photos wen i go home.
Im taking another guy with me to show him and will suggest if it is easier to find a way from the ceiling rather than from the roof above.
Thank you Tony.
T
