If its an auto defrost one, water passes through a hole in the back, usually just above the salad drawer, and down a tube to a tray which is on top of the warm compressor - therefore evapourating the distillate off.
If this tube is blocked, the fridge leaks from the inside.
If the tray is full of rubbish, the fridge can leak from the outside.
John
