Hello All you fab people who help me out all the time
I need some opinions on how to sort out these joists that are gettnig wet everytime it rains.
So as you can see from the pic joists 1-5 need to be removed from the wall and cut back a bit to stop them touching the wall / space where the air brick is.
the way i have been advised is to cut each joist about 6 inches away from the wall and put in some joist hangers on joist 1 and 6 and run a new joist across to conenct the old joists to
this idea i think would be ok if i did not need to repalce joist 1 also as its wet inside the wall.
someone did mention a polythene cover that goes on the end of joists to keep them dry.
this takes me to my second idea
shoudl i cut back joist 1 and screw the new joist hanger to the wall and joist 6 conencting all old joists to the new corss joist?
i am also thinking of removing the step that is pretty much on its last legs and putting in two cources of brick to make the new step and the french doors to sit on.
Any ideas would be great cheers all
