Right so I recently moved into my council flat.
It has a wet room. Which has a shower, sink and a bog (toilet).
If water from the sink goes on the floor or if you **** on the floor next to the toilet, it will flow past the shower and towards the door…
Which obviously will cause issues.
i stuck down one of those rubber bumps from eBay. But after few months it’s coming up and probably can’t be reused because it’s going to be filled with dry sealant (as per instructions!)
Anyway, what should I do?
The council haven’t exactly been keen to fix other issues that definitely needed fixing. So I feel like getting them to fix this would require a wrestling match or two.
What can I do? Is this something that needs fixing or what?
