- Joined
- 21 Aug 2021
- Messages
- 10
- Reaction score
- 0
- Country
Hi all, will be getting a plumber to do the work but have had differing opinions and want to crack on with the other work required which means I need to raise the floor to the correct level. I live in a second floor flat, there's one flat above me. I'm adding a small en-suite wetroom but the soil stack connection is pretty awkward. Toilet will be going just to the right of the stack and shower just to the left, with sink pretty much right in front of it.
What's the best way to make the waste connection as low as possible? The soil stack goes into the concrete floor. I was thinking it would be best to cut it as low as possible, then use something like this, but it says this should only be used on ground floor because it reduces internal diameter of the pipe?
www.screwfix.com
Also the gas meter pipe is right in the way and will need to be rerouted! Here are some pics:
photo hosting sites
McAlpine Push-Fit Single Socket Drain Connector Black 110mm - Screwfix
Order online at Screwfix.com. Polypropylene drain connector with 'O' seal socket. Finned seal spigot for internal connection to 110mm cast iron, plastic or clay. Ideal for low level connections. FREE next day delivery available, free collection in 1 minute.
photo hosting sites
