what am i doing wrong, masons mitre
13 Nov 2006
Kent
Hello all,
A lot of the kitchens I fit end up having worktops that are different widths due to batoning base units off the wall by different thicknesses. So I set the jig for the female cut say 647mm for width of return worktop and router, then set the jig for the male cut and router, when I bring the two mitres together they align perfectly but i end up with an offset on the female cut of about 1.5mm at the 90 degree of the post form edges. Or in otherwords the male shoots past the female at the intersection of the 90 degree causing a 1.5mm gap?
I changed my clamps thinking it could be them causing the problem, but it made no difference, has anybody experienced this problem. The jig is not damaged albeit I didn't spend a fortune on it, could it be the jig?.
Cheers for any replies
No idea what the make is, cost me £50 reduced from £75 apparently, which answers the questions really.
Better go and buy a decent one then can you recommend any that aren'tgoing to break the bank, iI could probably go to £150 - £200, cheers
Hello all,
Why baton base units, just causes problems.?
When you do the male cut place a 1.5mm shim between the worktop and locater peg. Try that on a scrap piece.
If that doesn't cure the problem then the jig is likely at fault.
Why do so many kitchen fitters trash their routers cutters doing the cut instead of using a jig saw?
