Hi all,
Need to replace my shower pump but have run into a small issue:
Pipes and fittings are very close to fitting. I can possibly try and get away with the two outlets as you see pictured (two at the rear, not push-fit connected yet), although it will be a little high.
This leaves me with needing to by two different hoses to fit the inlets and there are no valves fitted to allow me to isolate the water suplpy.
Are there any options open to me which don't require isolating the hot and cold water as I can't find the hot isolation valve. Can I isolate the cold water in the left using those two large shut-off valve?
Pictures to hopefully provide some more clarity:
Appreciate any advice!
