Where in the uk are you?
the best combi boiler is the Intergas HRE (IMHO )
The fewest moving parts of any combi
no plate heat exchanger to block
no diverter valve to break
no auto air vent to leak(the boiler does not get air locked)
the most flexible and future proof of any combi
A rated in CH and 95% efficient in hot water(one of the highest you can get)
it is about the only boiler designed to be reliable.
It does. The installer has a job when he sticks the boiler in, followed by a steady stream of repeat buisness, when he comes out to repair it.buy made in britain U know it make's sense
I want quality & reliabilty, as had lots og prob with my current Baxi system. Want to pay thhe right price for an efficient system that will last me for yrs. Thxfor the op to answer your queastion you must first ask yourself what your priorities are otherwise your only going to get narrowed minded biased installers recomending the limited products they support.
saying that i myself only aprove of a limited range of boilers 5 manufactures to be exact and about 10 models but then thats because there is so much rubbish out there and the products i aprove of will genuinly cover all areas and your requirements
are you concerned about price
are you concerned about energy eff
are you concerned about the size of the boiler
are you concerned about the quality and reliabilty
you see so many question you need to ask yourself and present to the installer before he can even begin to install a boiler that you actually want! otherwise youll end up with a french sounding boiler thats cheap for installer to fit but will proberly last you all of 2 months
The early Ferrolis had no diverter and no separate HEX and they were pretty crap from a reliability perspective. They were very similar to the Intergas design but were not as efficient (being 15yrs ago).
So I remain unconvinced.
thx for the reply, I have 14 rads, 3 bathrooms, kitchen and utility room is Valliant eco 831+ sufficient size boiler ?well in that case i would revert you to my high class range featuring the following manufactures
Atag
Vaillant
Veissmann
all band A boilers expect to pay the price tag! and under no circumstance expect to pay the same price for one of these boiler as you would in wickes or B&Q
if you want a mercedes you pay mercedes prices and not the price of a skoda
regards
sounds perfectly reasonable please point me to the Ferroli that looks "very similar to the Intergas design" please
the words 'your talk out your a**e come to mind'
tehmina";p="1606910 said:AkuraEngineer";p="1606866 said:well in that case i would revert you to my high class range featuring the following manufactures
Atag
Vaillant
Veissmann
regards
thx for the reply, I have 14 rads, 3 bathrooms, kitchen and utility room is which size/model boiler would you recomend. I can't seem to get prices for Atag system and again which model should I look for?
Many thanks in advance
