What cables to use for a cooker/kitchen
17 Aug 2007
Hi All,
Please forgive my total lack of electrical DIY knowledge before I start.
In March I had a complete rewire done on a house I bought last November. The kitchen sockets are on a separate ring circuit to the rest of the house sockets/lights. This ring has a trip switch fuse of 32A.
On the wall is a fused control unit leading off to a spur under the work surface where there will eventually be a cooker hard wired into a junction box.
This is where I show my complete lack of knowledge... As I been working my way around the house plastering up the conduit channels I've noticed that all the wiring looks the same throughout the house including the kitchen ring circuit and this cooker spur (standard 2.5mm???)
Shouldn't the wiring for the cooker spur, or maybe the entire kitchen ring be a thicker wire if it is on a 32A fuse?
Am I going to die a horrible death when the kitchen wall catches fire? HELP!
You use the word cooker - do you really mean cooker or do you mean oven or hob? Are they electric items or gas? You can generally fit a single electric oven to a 13A fused spur, but an electric hob or cooker (a hob and oven/s) will require it's own dedicated circuit and can not be spurred from the kitchen ring circuit.
A kitchen doesn't require larger cables, a dedicated circuit wired in 2.5mm² t&e on a 32A MCB is fine.
At the moment there is a 'cooker' plugged in via a thick cable.. NOT ideal I know!!!
But when I eventually have the kitchen refitted I intend to have an electrical oven with a gas hob unit above.
In that case, as I mentioned previously, a single electric oven will be fine connected to the fused spur you have available.
