I will need to cut a trap in already fitted laminate flooring. Can I ask what circular saw blade should I use. Will only be doing this once so I like to keep the blade cost to a minimum if possible.
Thanks,
Pete
Thanks,
Pete
You make good points, thanks. Setting the blade depth to the thickness of the laminate and yes to reuse the removed laminate are my thoughts to start with. As for services, I’m not 100% but I will make every attempt to check .
