i was skimming a small room, the centre light cable was just poked back through the hole made in the ceiling,there was no connectors just the bare ends,when they were pushed back the switch live and neutral were touching,although no current was there as the pull cord switch was removed,and the live and switch wire were taped up separately.
when i skimmed the ceiling first the plaster forced its way into the ceiling hole(normal) when i began the walls i noticed a tingle when i touched the wet plaster,got a mulitmeter out went back into the room and just the probes being in the room gave me 64volts,same slightly more when i put to wet plaster.
obviously tripped the lighting circuit and all well, hooked the cable back down ,separated the cables and choc boxed..
why did this happen when there was no current to the lamp cables ?
