Because it would be an unnecessary feature.I have never worked out why with low voltage kettles you don't have insulation to keep the water hot?
A kettle is for boiling water, and the correct way to use it is to boil what you need, not more than you need, so when used correctly there is never any water to keep warm.
Insulation to reduce losses whilst heating is a different matter.With extra low voltage they do put insulation around the cup boiler.
Please provide a logical explanation of why putting the amount of water you need into a kettle will leave you short of what you need.I always fill to the mark as so often when I have not I have been short of water,
No - stupidly unthinking carelessness is not a reason to implement a deliberately wasteful method of operation. The alternative of using it correctly so that there is never any water left in the kettle means that people will soon learn that if they want water they need to put some in the kettle. Anyone who is genuinely incapable of doing that should never be allowed to use a kitchen unsupervised in the first place.or some one has switched it on without checking. So to save element always left full.
Please provide a logical explanation of why people cannot detect the presence, or lack, of a kg or more of water in something they are holding.The gauge in the kettle is rather poor, unless you shake the kettle to remove any beads of water in the gauge it can look full when really empty.
Also please note that the alternative of using it correctly so that there is never any water left in the kettle means that the kettle is always empty when someone comes to use it, so the gauge is irrelevant.
