I've got remove a 150mm strip downwards for 1 metre, so that a new window can be installed.
Regular brick/block cavity.
I've got a Makita 115mm angle grinder.
Do you think this will work;
Use the angle grinder to give me a straight line but only manage to cut in about 50mm then
remove back of bricks/reminder with bolster.
Then go in doors and do the same on the blocks.
Or is there a better way.
If you suggest hiring - can you give me the best size, taking into account it is not a huge amount to do.
This is the first time I've used an angle grinder so I'm surmising that my
thoughts above will work!!
Many thanks.
Stephen
