What is this called?
13 Aug 2019
Hi All,
Apologies in advance if there is a better location for this post. I need to replace one of these metal brackets on a five bar gate: it's used to secure an extra bar but I cannot for the life of me find out what they are called or where I can get one. Is it a question of getting one made up or does anywhere stock them?
Thanks for any help,
Stu
Thanks John: now I look at it I think you might be right. Any suggestions for what to use? I suppose I could get a hinge or find something similar but if there's a better method for attaching an extra bar (to make dog-proof) then I'd be interested to hear it.
Stu
Sure, if you went to a builders merchants and looked at 'builders metalwork' I'm sure you'd find something - and there's a good chance it would be galvanised too.
Failing that, galvanised 1" mesh should fit the bill.
John :)
When I needed to fix my concrete side fence post to the side gate that ran as a T across the front. I bought a galvanised steel strap from a builders merchant
Dog proofing- I would have thought that welded mesh would look better
