I'm wiring up a light in a bedroom and I was hoping to make it 2 way but after I assembled the circuit I tested it and found avoltage on L1 and L2, of 230v and 100v, flicking the switch flipped the voltages round.
The wiring system was organised in the following way:
This is an attic bedroom, and a spur was run from an existing lighting ring so I have a single entry point presenting 240v at the switch. I joined this live to common and passed the neutral straight into the 4 core.
Half way along the 4 core, I've split the insulation open and cut the two possibly-live cores, putting them onto L1 and L2 of the slave switch, picking on one exiting live core, to go onto the light:
[code:1]
L1-----L1
LIVE ---COM/ \COM------
L2-----L2 LIGHT WILL GO HERE
NEUT --------------------------
[/code:1]
The light isnt in yet so I was expecting to see a nice and simple outcome to my tests, that L1 / L2 on the master would have 0/230 depending on the switch position.
Seeing that about 100v is present on the core that should be 0, and also having observed that if I put the voltmeter between the live supply and e.g. a nail driven into the wall, I also get 100v I'm suspecting that at some point on the cable, both cores leak into e.g. the plaster of the wall, but not each other.. If a screw had been driven through the wires, bridging them and earthing them I would have expected the bridge to cause 230v to be presented on each regardless of the switch position, but given that they both present 100v, i'm thinking that somehow both cores have been grounded and the leak from one core to the other is 100v..
What is really confusing me though.. I've currently got the circuit like this:
[code:1]
L1-----SL1 LL1------
LIVE ---COM/
L2-----SL2 LL2------
NEUT ------------------------------
No light in circuit - should just be a wire in the ceiling terminating in (no connection) as in diagram
SL = to-switch live core
LL = to-light live core
[/code:1]
The master switch is switched so that L1 is getting 230. The slave switch has been removed and all I have are the cut wires sticking out the wall (with the neutral uncut). Putting the multimiter between the following gaps I get the reported voltages
SL1:SL2 = 120v (up from before - it's raining outside??)
SL1:LL1 = 230v
SL1:LL2 = 230v
SL1:NEUT = 230v
SL2:LL1 = 85v
SL2:LL2 = 90v
SL2:NEUT = 100v
LL1:LL2 = 0v
LL1:NEUT = 0v
LL2:NEUT = 0v
It's almost like someone wound a screw through all 3 cores up in the ceiling on the light side of the circuit, because every core functions as a neutral to the live 230v.. But the voltages definitely differ when the LL cores or the neutral are used with the leaking 120v voltage from the SL2.
I have done a DC continuity test and there is no continuity between any of the cores, so I don't think a screw has been wound through it.. Multimeter was set to max ohm scale for this test, to catch any connection having a resistance up to 2000 megaohms; all core connections showed as infinite resistance
Can anyone suggest what's gone wrong/where I should look for the fault? I suspect there might be two wiring faults; one on the light side that makes all cores function as neutral, and another on the run between the switches which presents about 100v on a line that should be 0v
Thanks in advance for reading my lengthy and boring post!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
cj
[code:1]
L1-----L1
[/code:1]
[code:1]
LIVE ---COM/
[/code:1]
SL1:LL1 = 230v
SL1:LL2 = 230v
SL1:NEUT = 230v
SL2:LL1 = 85v
SL2:LL2 = 90v
SL2:NEUT = 100v
LL1:LL2 = 0v
LL1:NEUT = 0v
LL2:NEUT = 0v
cj
