What paint for bathroom ceiling with mould?
OM2
18 Jan 2007
We've got black specs in one corner of our bathroom.
We've got an extractor, but have still got the problem.
What paint do I need to cover?
Is there any treatment I should apply before the paint?
Thanks.
I've never used it, but I'd get something like this https://www.toolstation.com/ronseal-6-year-anti-mould-paint-25l/p86512
If you can get to the loft, assuming there is one, then try to get more insulation above the bathroom. And maybe replace the extractor fan.
I had mould on ceiling in my bungalow (solid walls, poor insulation) but since piling loads more insulation up there the mould on the ceiling has stopped. Still grows in other areas. I have a heater in the bathroom, wall mounted near the ceiling, which really helps get the moisture out in winter after a shower.
We've got black specs in one corner of our bathroom... We've got an extractor, but have still got the problem...Is there any treatment I should apply before the paint?
Yes, you need a better extractor, or to turn it on more often.
Show us some photos please
You must clean the old mould and kill the spores (specialist products of bleach). Rinse afterwards. Do not paint over mould.
I've just recently & successfully solved your problem at great cost, both in time & money, to myself.
Kill the spores with a solution of 50/50 bleach & water, or for £1 a bottle "Astonish Mould & Mildew Blaster". Then paint it with a Zinsser anti-mould paint.
Most of my life has been devoted to finding this solution.
Thanks for the replies guys.
So I need 'Astonish Mould & Mildew Blaster' - and NOT to use bleach?
See below for a pic of the problem
QUESTION: after applying anti mould 'stuff' how long should i wait before painting?
ALSO: is there a cheaper alternative to the Ronseal paint? I looked in Screwfix, I find 'Primer Sealers'.
The reason why I ask is... when we had the painting done, the 'proper' paints would have been used by the painter... but we got the mould start coming back after say 1 year...
So... if it's a case of using anti mould spray + white paint, I'm happy to do once a year (not that I actually want to - would prefer to paint once and forget about for 10 years).
Let me know.
Try moving your extractor to directly above your shower. I found that extractors 'drag' the moisture across the ceiling.
@bourbon it's actually literally above the shower head!
The extractor is a pain... we turn on the light... and it turns on after 10 seconds.
Then only goes off 1-2 min after the light has gone off.
Given that we have a mould problem, this setting should stay?
Of your fan.
It is very likely that we can suggest one that actually works.
If the ceiling is cold, an extractor fan won't get the moisture out the air before it condenses in the corners.
Insulation + heat with extraction.
I bought an extractor with the ability to shift 280 litres of a water an hour and still had condensation and small amounts of mould, albeit much worse than when we had the small "inline" extractor by Manrose. So it is possible that a stronger extractor fan is not your answer.
First of all check to make sure the fan and the ducting are set up correctly to extract air from the room and also make sure there is a small gap (8-10mm) underneath the bathroom door to allow fresh replacement air to be brought in.
I cleaned my walls down (get rid of the existing mold!) and painted with an anti-mold paint. Now when we've had a shower yes we get some condensation on the walls but I have not had mold in over 2 years.
It must be said that while we have a shower with the fan on, we do switch off and fling the window open for an hour or two when done. I personally think this is the best way to ventilate post-shower rather than having a fan on an overrun.
yep, that's why I said insulation + heat. That works. If there are cold spots and the water condenses quickly, and extractor fan can't get it out of the air, you need to wait for the ceiling to dry out and evaporate.
