Hello
Ive just fitted a new 15-50 , ( swapped motors actually ) and I had major problems trying to loosen the nuts on the grundfos pump
( The nuts are from the Isolators fitted on each side )
my query is;
can someone tell me what the correct spanner size required is ?
I tried an adjustable spanner, < > 40mm but it wasnt large enough
I used grippers in the end, but I hate using them as easy to start rounding off the nuts
I would like to know the correct size, so I can order the correct fixed size spanner
thanks
Teddy
ps: using a micrometer as best I could, the size seems to be around 50mm, but this isnt an exact measurement as meter guides not long enough to reach nut faces correctly
my query is;
thanks
Teddy
