... or, at the very least, is not a 'DIY' matter!this is not possible and methinks this is trolling
None, because such a design is fundamentally flawed.What size cable is required to feed a consumer unit 30m away from meter, which feeds six independent 10kw electric showers each 4m apart?
A more realistic solution is a stored hot water system, where the water is heated in one or more hot water cylinders - and for 6 showers, those cylinder(s) are likely to be fed from stored cold water, rather than direct from the mains.
Quite so ... but, even if they did, six immersions would require a hell of a lot less electricity that six 10kW electric showers!The question is impossible to answer without a knowledge of the purpose of the showers and the useage. I would assume that six showers would not require 6 cylinders to supply them.
Get a gas boiler
