Internally please?Interior or exterior wall?
Sleve or no sleve?
Andy
Brilliant - Thank you.Try to drill at a slight upwards angle from the exterior side so rain will naturally flow out of the hole.
I was going to say the same. I always use 20mm round as it's easier than drilling oval holes.Brickwork is rough and will chafe the cable so you should use conduit
I'm fitting an outdoor socket. The outdoor socket is gonna be wired to a plug as opposed to being hardwired (spur).Brickwork is rough and will chafe the cable so you should use conduit
The cheapest is probably the oval that's used for chases that will be plastered over, you can buy a length for about 50p,
Tower Oval uPVC White Conduit 16mm x 2m - Screwfix
Order online at Screwfix.com. 16mm, robust, heavy gauge material construction to protect electrical wiring routes. Can be cut to size. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Though 20mm round would be more elegant
Deta TTE Round uPVC White Conduit 20mm x 3m - Screwfix
Order online at Screwfix.com. Manufactured from high impact, robust heavy gauge uPVC. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
I suppose if you had an offcut of plastic pipe handy you could use that
Thanks. I always blow out the plaster.And for direction, think about which side matters most, and which is the easiest to repair if necessary. e.g. plaster is easier to fix than facing brick.
16mm flexible conduit will take most cables you'd want to get through.
Are you saying that after drilling the hole (cavity wall), a better job would be to stick 20mm round conduit in the hole to prevent possible damage to the cable?
