I have an existing extension built in the 1980s with what I term a standard 11 inch wall i.e 100mm brick outer, 50mm cavity (rockwool filled ) and 100mm celcon inner layer with 12mm plaster scim .
I now want to build above this extension ( and carport ) and need to know what dimensions the new first storey cavity wall dimensions need to be .
I 'd prefer the same construction i.e matching external bricks but I have heard that the cavity has to be beteween 75 100mm and with the 100mm celcon inner leaf I am a tad concerned how I go about this .
Note as part of this new extension I plan to build over the existing carport so there will be long 4200mm lintels , do I will need to have the same cavity wal construction above this as the first floor extension will essentially be a single room so a change in wall width will be unnacceptable
OK experts have you any advice , tIA
