I need to remove a stud wall at my local social club but the problem is is that the wooden roof supports are sitting on it. I need to install steel beams as i understand you cant join the existing supports together but im trying to work out the steels without spending a fortune on structual engineers and all that. The beams will only be supporting a flat felt roof and the span between the two walls will be 6.6 metres. One end of the new steel will be sitting on a solid brick wall which i will put a pad stone on but at the other end i have to put in steel posts because it is a timber wall (exterior wall). Has anyone any idea about the size i would need or where i could find out with out it costing a fortune ??
I know from experience and would have thought it would be something like a 200 high by 120 wide with post of 100 x 100 and 5mm thick ??
Also the floor that the supporting posts would be sitting on is concrete so im hoping that i wouldn't need to put in a footing for each one ??
