Hi Folks,
Apart from the subject question, can anyone advise what the maximum temperature a thermal store should be allowed to get? As some of you are probably aware, we have a bizarre system for our hot water+central heating combining a multifuel stove/immersions/solar panel.
The Resol unit tells us the temperature in the tank top and bottom.
The reason I ask is that our system has to incorporate a failsafe device into it, a gravity radiator/thermosyphon thing that operates when there is a power cut, the pump stops working for the central heating and the store can't shift any heat from it when the fire is on this is supposed to cut in and take over safely removing excess heat.
Well I've had our tank up to 100.1c(turned off the heating mainswitch) and this gravity fed thermosyphon thing has not kicked in at all. The system is all bled and fine, but at this temperature the store sounds like a huge kettle boiling away. The minute it got to this temp I restarted the pumps and opened up the radiators to drop the temp.
So prior to going back to the installers what should the max temp of a thermal store be? 90-95? It surely shouldn't be anywhere on the boiling point especially if it's pressurised(Is it?!?!)
