Hi Folks,
Can any of you please advise me whether this thermostat should be open or closed under electrical load? (I'm sure it's open by pipe temp and what's on the top of it with the A>B Open bit...?)
Problem is this is attached to retrofitted plumbing to a thermosyphon/gravity radiator which should operate under conditions such as a power cut(it's from a multifuel stove). I.e. it should be closed normally and when power fails(stopping the central heating pump) this is designed to open and to leak heat safely through this big radiator in our upstairs hall by opening the "circuit" to it, and prevent the thermal store from boiling.... But ours failed to work at all during a 26hr powercut last December. The installers FINALLY came around last week and I monitored them as they checked it out. Turns out their company had left the valve shut to the radiator(so no water was ever going to flow through it) and the thing wasn't even connected up electrically!! I've a feeling the thermostat is wrong and this is the reason it wasn't wired, as now they have done it and opened the valve this "emergency" radiator now has heat in one corner of it all the time, whilst 2 neighbours in identical houses ones work perfectly, and are stone cold but did work during the cut....
Can anyone advise me further? Absolute cowboys.....
