    Dismiss Notice
What to seal a untreated wooden staircase with ?
Discussion in 'Wood / Woodwork / Carpentry' started by johnnewby, 19 May 2019.
Tags:
  1. johnnewby
    johnnewby
    19 May 2019
    Thanks Received:
    Country:
    Hi I have removed the old carpet from my stairs .The wood underneath is untreated .I have sanded the wood down and filled the edges that connect to the wall/Bannister .What would be best to coat the floor with ? Many thanks John
  2. JobAndKnock
    JobAndKnock
    30 Sep 2011
    4,014
    Thanks Received:
    820
    Lancashire
    Country:
    That's actually fairly common. In the days when stair carpet runners were installed which were narrower than the actual treads the visible edges would often be either painted or stained and (French) polished or lacquered. You can do this across the full tread, but the finish will wear quickly (stairs are high-traffic areas) and without a carpet they will be noisy
  3. Gerrydelasel
    Gerrydelasel
    5 Jan 2016
    2,220
    Thanks Received:
    186
    Lancashire
    Country:
    What do you mean by 'treat'? Are you expecting to leave it uncarpeted? In that case a thick cost of oil-based paint (on primer) is your best bet. Varnish will wear through pretty quickly.
  4. bernardgreen
    bernardgreen
    3 Nov 2006
    22,706
    Thanks Received:
    2,137
    Bedfordshire
    Country:
  5. Sponsored Links
  6. Mr Chibs
    Mr Chibs
    28 Jul 2015
    395
    Thanks Received:
    61
    Country:
  7. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
