What to use for these joints
20 Oct 2010
Lanarkshire
I asked this before but have had a lot on my mind and let it slip but now have to finish this. So dropped a new 3&e to light switch and I am lowering the ceiling and the attic above is floored so no access, what do you recommend to fix these joints , the cable on the right is the 3&e to the switch I was going to fit a 4way jb but want to do it right as far as I can ?
Maintenance free junction boxes will comply and do the job.
Soldering seems very much en vogue on the forum at present, but personally I don't recommend DIYers doing solder joints that can't be accessed - I think there's too much a DIYer could get wrong.
Sorry no access to these joints
I think that the 'access' chivers was talking about was that which can often/normally be achieved through the hole in the ceiling in which the light fitting normally sits. In other words, if, having pulled the light fitting down you can get at the JB, then many/most would call that 'accessible'.
Kind Regards, John
Kind Regards, John
Thanks but no play in the cables, so the only way I see it is fit a J804 at the original ceiling with these wires, or extend the wires to the new dropped ceiling so I could pull through a light fitting hole for access
Fair enough.
Kind Regards, John
