What type of connector block is this?
9 Sep 2005
Initially thought it would need a male bullet but I bought the smallest one available (red 4mm) and it was way too big for the hole at the top.
Maybe it needs a female connector? Each one is about 6mm wide.
It's on an indicator stalk of an old VW camper
You are holding a male bullet block connector, 6mm.......you need the female to match it. Nothing is meant to fit in the middle hole.
John :)
It certainly should be! You can always crimp it up a bit if its slack as it doesn't look like the original VW part - unless its a Brazilian made camper with the Polo engine in the back.
Always solder the connections for reliability, if you can.
John :)
Cheers, it's not a stock VW part. Believe it's a stand from an old Land Rover.
Many thanks for your help!
