Hi all, I after building a brick shed at the bottom of my garden, it will be 12m x 4.5m. do i need to put footings in, or would i be ok with a concrete base. also, what depths should i go for.
Eh you need to post up a bit more info than that. Also it's not really a shed if its built from brick and at that sort of size you'd almost certainly need proper footings.
What height? single brick? 9 inch? full 2 skins cavity? What's the use?
