What wire do I need?
27 Sep 2011
I'm fitting an external floodlight
I plan to power the floodlight via a nearby socket
e.g. 2.5mm, flex etc
Out of curiosity, if I was to wire the floodlight into the lighting circuit, would you guys recommend 3 core flex in 1mm2?
Could I even use 0.75mm2?
I am not an electrician------ Given the cost differential, why pay for 0.75mm rather than 1.0mm?
I'm not planning on using either
cable as I will be wiring the floodlight to a socket.
So as advised, I will use the 3 core flex, 1.5mm² in black
Thanks for the help guys
