What's best flooring material, upstairs on 400mm joists?
9 Feb 2007
Yorkshire
Hello,
I want to lay an upstairs floor in a dry outbuilding. The joist spacing is 400mm. Total area is 52 sq m. There is no floor at present.
I'd like to use a sheet material for speed - chipboard or plywood?
T&G edges would be nice, if this means I don't have to cut boards to end on joists?
Can anyone tell me what material and what thickness is best.
Many thanks Phil.
I would avoid both woodchip and ply. Ply has shot up in price recently and you will have a lot of waste end matching to a joist. Woodchip should never have been invented, it's cheap but will squeak !! all day long. Why not use pine T&G flooring in either 19mm or 22mm.
You never said what finish you were after, carpet, vinyl, wood etc. That might help you decide.
thanks for the reply mac.
As this is an outbuilding, I'm not planning to finish the floor with anything, though I might put some rugs on it. It will only get light use.
I've laid pine floorboards before and it takes a while. I'm hoping by using a sheet material I can get it laid in a day.
