The neighbour has already purchased the wastepipes (white) and elbows (grey) . The other wastepipe serving the same flat is also painted black. Yes, it does look naff but at least in this case there is consistency in the naffness.
Dulux Weathershield is a nice shiny , flexible, black. DOn't use undercoat.
If you want black pipes which don't go "off" like Polypipe, use Terrain. I daresay some others are OK too.
Rub the pipe down with sandpaper first to give the paint something to key into. After that more or less any exterior gloss you care to mention will be fine. Its a good way of protecting the pipe from UV light which gets to them all sooner or later
