What's the best product for hairline cracks in new plaster?
23 Jun 2006
Hi there,
I've just had a plasterer skim my entire living room, and there are a few external box sections where the plaster has cracked slightly which I was kind of expecting becuase they are more comlex than your average flat wall.
He used external beading on all edges, and becuase they're external boxes, all 3 beads meet at a point, and this is where the cracks have formed. I've done a mist coat and would like to know the best method/product for filling them. I seem to remember reading on here that you shouldn't use ready mixed polyfilla, but mix it yourself..?
I've searched on here and seen that some people recommend caulk, but I dont like the idea of this if it'll start to shrink. What filler what a pro use?
Thanks in advance guys.
Don't use caulk, it will look awful; powder filler is OK but decent, pre-mixed fine fillers also work well & need minimal sanding.
Gyproc Easyfill is good but the minimum quantity you’ll have to buy won’t be much use for you. I've used Polyfilla both pre-mix fine & powder filler & also Mangers ultra fine filler. To be honest, I find they all do the job & I only use it in very limited amounts; my plastering work never needs much if any remedial filler. :wink:
Ok thanks Richard. I think i'll just get some easyfill if thats the best gear for the job. Would this be fine to also use on blemishes here and there before painting?
Yes; it's intended for use when filling & taping taper edge board joints on dry lining but is an excellent, easy sand filler.
