What's the best way of stripping paint from a wooden door
30 Aug 2010
London
I'd like to strip my front door. It has varnish and black gloss painted on. Should I go the Nitromors way or would you recommend stripping with a torch and scraper
Agree with Robbie. Even an electric stripper if you don't fancy gas. ( when I first used paint stripper in the mid 70's one coat then did an awful lot of work).
Modern nitromors is absolutely terrible,if you go the paint stripper route I would recommend something much stronger. Last one I used was called starchem synstrip which was really good but that was on metal so would be best to check if its ok to use on wood.
Anyone else has expereince with paintstrippers? what's better http://www.ebay.co.uk/itm/VERY-STRO...Material_Paint_Varnish_MJ&hash=item3a89932b76 OR http://www.ebay.co.uk/itm/VERY-STRO...Material_Paint_Varnish_MJ&hash=item3a89932b76
