Just refilled my system and a few rads will not come on. I'm assuming I have an airlock somewhere but I just wanted to clarify something.
On a cold radiator, I use a drain off valve or bleed key to take out a reasonable amount of water. I then find one of the pipes getting hot, however, it is the return pipe. Does this make sense? In the back of my mind, I'm now starting to worry as I have a few column radiators where the flow has to be on one side. These radiators previously worked so I am getting a bit confused, but if there is a lock somewhere on the feed side, then the only place for hot water to come from should be the return, right?
