- Joined
- 7 Feb 2021
- Messages
- 27
- Reaction score
- 0
- Country
Hi all,
We have an old-ish open vented system. It may date to when our house was built in the late 1990s. The boiler is an Ideal Classic although I can’t see a model number anywhere on it.
It generally works ok, except that if the heating and hot water are both on at once, the hot water never really heats up.
I don’t think there is a problem with the 3-way valve. If I put the heating and hot water on at once, all three pipes from the 3-way valve become very hot very quickly which suggests to me the water is being circulated properly from the boiler to both the hot water cylinder and the radiators. However, the pipe coming out of the bottom of the hot water cylinder (i.e. the water returning to the boiler rather than that going to the taps) is only moderately warm after 30 minutes or so. Again, after 30 minutes on both, the water to the taps is only lukewarm whilst it would be hot enough to run a bath after about 20 minutes of the HW alone.
I don’t notice any impact on the radiators if both are on at once.
I had a chat a heating engineer who suggested that the pump (a Grundfos Selectric) might not be powerful enough (perhaps through wear) to circulate enough water to heat both. That seems like one possibility. But before we get him in with a view to doing that, I was wondering if there were any more investigations I could make?
I have read somewhere that there is a valve that is supposed to regulate the priority of flow of water between the HW and CH systems. I was wondering if that was overly-restricting the flow to the HW? If so, where might it be and how much would anyone suggest I adjust it? There’s a valve on the return pipe from the bottom of the cylinder: might that be it?
Any other thoughts?
Thanks very much!
Any other thoughts?
Thanks very much!
