Where best to insulate
9 Dec 2009
West Midlands
Guys,
Ripped old old plasterboard from 18 year old extension as I am refitting the kitchen, have found a small layer of fiberglass insulation and absolutely nothing in or on the rafters.
Would it be best practice to insulate rafters, I was thinking 100mm Celotex in between the rafters & 50mm all over after that (Warm Roof Setup).
Or would I be able to do something similar but do so to the ceiling joists in a similar fashion?
Thanks for your help
Why heat the roof void? Better to insulate the ceiling ony, and make sure there is sufficient ventilation to the roof void.
Strictly, this is a Building Regs matter
(Incidentally, what you appear to be describing would not be a warm-roof set-up).
Don't insulate rafters unless you are making a room up there. Insulate at ceiling level
