I've been tasked to replace the following sink which is built into the counter top. The taps have apparently been leaking for years and the sink has a gross amount of limescale built up.
Ideally, I'd like to find a sink of the same size and shape, so I can just swap it out. I'd really rather not have to replace the counter top as it's a really awkward shape; I guess getting a slightly bigger sink wouldn't be so bad as I could just make the hole bigger - but same size would be ideal.
Sink is 17.5" / 445mm deep x 22" / 559mm wide. I've had a look around online and can't see anything like it, does anyone have any suggestions as to where might sell one?
Failing that, is there some chemical that I could just pour on and dissolve all the limescale?
