It looks as though I'm either having a conventional boiler (Ideal) fitted by the front door or a Vaillant combi in the attic. This is to replace the old back boiler.
I haven't had the quote yet, but although I'd prefer the boiler to be in the loft, I expect it will cost an awful lot more (£2K?) than the conventional by the front door.
In either event, the pipes will join up to most of the existing pipework rather than a new route be laid.
This means the hot water run will be very long: if the boiler is in the attic, the pipe will run from one side of the loft to the other (the installer doesn't want to put the boiler on the chimney side of the house for some reason)and then down into the airing cupboard. The hot water will then run under the first floor floorboards back to the other side of the house (under the boiler!) to the bathroom and then down into the kitchen.
If the boiler is by the front door I'm not quite sure what the route will be, but the hot water will have to cross the house somehow, whether on the ground or first floor, and I'm not sure how the boiler will connect to the ch system, since at the moment all the pipes run up the wall next to the back boiler chimney. The installer wants to run at least one pipe up from the boiler by the front door into the bedroom above, which is all of 7 foot square and pipework could, of course make it difficult to make the bed in there, there's so little room.
I feel very confused. Please what should I consider and what questions do I need to ask? (I've had a good search on these forums already, by the way.)
Thanks! :
Thanks! :
