I have recently had a couple of little problems with my boiler/ central heating.
I turned it off when I was replacing the kitchen, when I turned it back on, the boiler just laughed at me. It has leaked from every orifice and when I got it to hold water and ignite then it did so straight away. This lasted about 15 seconds, cough, cough, splutter, bang. Tried again, same again.
Called in a plumber. The flue was not connected to the wall outlet and the valves each side of the water pump needed replacing. The boiler runs beautifully now, the house has never been so warm.
My problem starts here, when the plumber fixed the boiler the programmer would not work, too much water flowed through it during the leaky bit. I have now managed to get the programmer to come on and go through the motions, it doesn't actually seem to affect the boiler at all, the heating is just staying on, keeping the radiators and water hot. (controlled on stats)
I have resigned myself to replacing the timer, but which should I go for? We were happy with the outgoing one, but don't want to shell out money for an out of date bit of kit.
Please help.
The system as it stands is:
Ideal FF240 boiler, pressurised system.
Drayton Tempus 6 programmer
3Kw megaflow hot water tank
Drayton room stat
TRV's
Think that is everything, just trying to save a bit of money, hence not getting the plumber to replace it.
Please help.
Drayton room stat
TRV's
