Hi
I am building a Rill (6m x 50cm x 50cm) in my garden. Found some instructions which I am following; these call for using concrete blocks to line the channel in which the rill will be constructed.
The blocks are to line the channel; a butyl pond liner will go over the blocks.
Question: Which type of blocks to use, aerated, medium or high density blocks? From what I have researched, aerated might not be a good idea, since water penetration and frost will damage the construction over time. Cost wise aerated are a bit more expensive, but they all seem to be around the 90p per block mark. I reckon I'll need about 30 blocks.
Also there seems to be some discussion as to the make of blocks to go for. Seems most favour B&Q medium density over Wickes. Any opinions?
Cheers
K
Cheers
K
