Which direction to lay felt
2 Mar 2003
Yorkshire
I am felting my summerhouse roof tomorrow.
It's is 5m long x 3m wide and slopes down the long side.
I have raised it 100mm higher at one end, so it is a very gradual 1 in 50 slope
My question is
Which orientation should I lay the felt?
In 3 or 4 pieces following the slope down the long edge
Or
In Several pieces 90 degrees to the slope?
Ta
What type of felt are you using?
A 1:50 slope is really not enough to use a basic nail on felt.
Did you build this structure yourself?
It's a summer house. The felt came with it, it's your standard capping felt.
The roof had no slope so I added firrings to create one.
Why wouldn't felt work?
There's going to be a fair bit of movement in the summer.....I'd go for across the length, I think.
I had to do a similar thing for someone once - it was one of those occasions where felt shingles in strips helped with the movement.
Of course, there's always the possibility of water being blown upwards with a minimal slope.
John :)
Ah, I see so the Problem is the potential for water getting pushed back up the slope.
I'll make sure I put two layers down well sealed and see how that fares over the next year. If no good ill Board and EPDM it next spring, I just don't have the finances this year, besides I have 4 rolls of felt to use up.
Torch on felt might work ok but nail on is nowhere near well enough sealed at joints to deal with so small a fall. Driving rain could easily push rain under laps.
Nail on felt is designed for shed roofs with a pitch, with such a small fall you need to use a higher spec felt as would be used on a small flat roof .
You should use a torch on felt and possible use a base layer too.
Who on earth made a summer house with no fall on the roof?
As john said the expansion and contraction is worth considering which is a good reason for a 2 layer system.
If you already have the felt and can't return it you could use cold adhesive rather than nailing it.
I agree, no fall is ridiculous but I wasn't aware that was the case till I'd constructed it. Shoddy company!!!
I was going to nail the first layer down (for movement) and then bond the second layer to the first using cold adhesive.
Do you think it's worth putting a small batten (under the felt) down either edge down the slope to form a lip and prevent water flowing over the sides?
