Imagine caulk that doesn't crack and doesn't shrink.Got any pics? How does it look post decoration?
So not an invisible repair then?Imagine caulk that doesn't crack and doesn't shrink.
Depends on who's doing it and how much effort put in. I can make both caulk and sealant invisible. Decorators use their finger to form the caulk into a concave bead. I use a square forming tool.So not an invisible repair then?
Depends on who's doing it and how much effort put in. I can make both caulk ans sealant invisible
Did you use your forming tool when you made this?Decorators use their finger to form the caulk into a concave bead. I use a square forming tool.
If you look carefully, you can see nail. Would a plier, a chisel, or my latest china soldering iron have been used on that? Captain obvious, we have here?I thought you used a hammer.
How else can a relatively consistent bead be made? Tool and tape were used. The jagged edges were cause by tape lifting. It's not a problem unless you nitpick with a magnifying glass. The gap between skirting and floor was not suitable for filling flush with the floor and a 45 degree bead was used. The end of the bead was tappered/blended with the thumb dipped in dilute washing up liquid. The floor is not under the skirting, it was cut with a gap from the skirting.Did you use your forming tool when you made this?
It's caulk under the bridgeSorry for attacking your beloved caulk. I have no patience and talk straight on things that irritate me
In that case, I would expect cracks under that bridge. You need hybrid.It's caulk under the bridge
Only if you built it...In that case, I would expect cracks under that bridge
Here's a "de-cracked" door frame to plaster wall joint. Impression of the sealant can be seen (lossy image on this site removed the detail) on the plaster wall side where masking tape was lifted off. People can nitpikc, but I am happy with the result. The joint is subject to small movement when the door is pushed, pulled or slammed. Nothing but hybrid will work.
You can disagree, but it won't stop me throwing them all out. Hybrid is one size fits all. It's not only superior. It's superior x 10.I disagree with your (blanket) statement that regular caulks are inferior products.
I don't seems to have trouble tooling. I can multi-pass on the tooling after curing if necessary. Washing up liquid stops the stickiness to the finger or tool.MS polymers are incredibly sticky and can be difficult to tool. BTW, washing up liquid does not work as a release agent. Washing up liquid works with silicones.
DIY'er is concerned with durability. Trade is concerned with profit - if it fails after a couple of months, that means more business.The caulk will be faster (and cleaner) to apply and a 10th of the cost.
My caulk doesn't crack, I don't use it. Everybody else's caulk crack, and that p*sses me off because it costs me time, energy, and materials.If your caulks routinely crack then something is wrong.
Not if you have experience and technique. EB25 used like silicone on interior glass here. Unlike silicone, this will never fail during its lifetime.MS polymers are incredibly sticky and can be difficult to tool.
