Which grout do you recommend
1 Aug 2014
I'm after a bit of advice, I am in the process of tiling floors in a hallway, kitchen and two bathrooms. The bathrooms also need to have the walls tiled.
One bathroom has a shower, and the other a bath.
I am looking at the same tile for the floor through out - A full body porcelain 600mm x 600mm.
The walls in the bathroom and shower will have 200mm x 333mm tiles.
What is the very best grout and adhesive I can use?
At the moment I'm considering using either BAL micromax/microflex or Mapei Ultracolour Plus Grout/ and keraflex.
I'm also thinking of using epoxy grout in the shower room and bathroom with tanking.
Depends what your motives are. If you are looking to avoid staining then kerakol fugalite eco is as good as epoxy, cheaper and much easier to use - it also doesn't gas you half to death when using it. If your looking for a quality normal grout then the mapei is great stuff, and so is bal.
