Which job first? skimming
9 Aug 2010
Yorkshire
Hi guys, im a newbie here and pretty much new to DIY alltogether but still pretty compitent
just got a 1 bed back to back in Leeds which needs work
Needs re-skimming as the walls are either coverd in textured wallpaper, rough, batterd etc. I want to do the whole house at once as it needs doing, i'll prob get someone in to do it.
I'v got an idea of what order i need to do things in, but as the architraves and skirtings need replacing, do i replace them then skim? or take them off and skim? I'll fit all them myself.
also, need a re-wire, central heating, new kitchen and bathroom, new windows and door. Do I leave the skimming till i have got the rewire and heating done? I'll fit the kitchen and bathroom after so I can choose where I want the kitchen and bathroom fittings after the rewire and plumb
this is basically just to clarify things in my mind, I just want it all done efficiently
Remove skirtings,architraves before skimming.
fit new windows, 1st fix electrics and plumbing then plaster.
Hi James, welcome to the forum.
Sorry if an obvious point - you'll need to get all the wallpaper off before skimming. Textured ceilings e.g. artex can be covered with plaster, but you can't cover paper.
thanks, this gives me something to think about.
costs are stacking up though, i'm a working student so may have to get the first fix electrics done and do the rest myself, e.g fitting ceiling rose's and faceplates etc. then get it all plasterd later on when i get the windows and door changed after i'v had central heating fitted and the plumbing done as leeds council didn't make a nice job of it lol!
oh and yeah i knew i needed to strip the walls. bloody annoying job though, i hope it dosn't pull the plaster off as im hoping just to skim over the original plaster?
OK, here is the order in which you need to work to get the best finish
strip walls and remove woodwork
new windows fitted
1st fix elecs
1st fix plumbing (if you want the pipework hidden that is)
making good all walls and ceilings ready for skimming
1st fix carpentry (if required, imo best to rip out old linings and fit new, then you know they will be square, in wind and true)
skimming
2nd fix carpentry
painting (buy extra for touch ups if required after 2nd fixing)
2nd fix electrics
2nd fix plumbing / tiling of bathroom
kitchen
floor coverings
PARTY!!
As regard to the electrics, please read up on part P, it is very important and could cause you immense problems when trying to sell your home if you ignore it.
Good luck, keep us posted and ask more if you need too
In the absence of Rich C (who is prob sunning himself in Spain:cool: and usually advises this)....if you use a steamer, go easy as over-steaming can cause the finish plaster to come away.
Hopefully your paper won't give you too much trouble, however you choose to remove it.
Look in decorating forum.
I find scoring with stanley knife, then a couple of soakings of washing up liquid and water often gets it nice and loose.
also cooler work than a steamer, although skimming iver old plaster that is infirm is a bad idea, check the bond is tight with no hollow sounding spots.
